Re: Mikey`s Mopar 470 on the pump.............GUESSES?
[Re: rb446]
#2076744
05/19/16 08:36 PM
05/19/16 08:36 PM
Posts: 43,303 Bend,OR USA
Cab_Burge
Being that I normally build and race pump gas street and strip motors I have my oil temps between 160 and 200 F and the water temps between 160 and 180 F on all my dyno testing. I've been told by more than one dyno operator, including Jason Pettis, that most motors they test will make more power with colder water temps than what I test with ![work work](/ubbthreads/images/graemlins/custom/work.gif) Mine normally don't ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) As already pointed out more than once, the engine dyno is a tool to measure changes, nothing else ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) We don't race dynos yet, do we ![devil devil](/ubbthreads/images/graemlins/custom/devil.gif)
[Re: Thumperdart]
#2076961
05/20/16 06:41 AM
05/20/16 06:41 AM
Posts: 3,210 robin hood country
deaks
robin hood country
I can't get my head round this, i was told a .625/.625 275/283 on a 107 was too big for my 470 with 440-1 heads with bowl and guide work, same comp, and yet here's a motor with a .776/764 279/289 at 0.50 and it make all this power, surely it should be a mutt down low but it makes over 700 hp at 6000 ? Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
[Re: Thumperdart]
#2076967
05/20/16 08:13 AM
05/20/16 08:13 AM
Posts: 10,019 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Once above the torque peak the penalties for low compression diminish a bunch I am sure. At peak torque reversion should be gone, so the power loss could be figured from a "compression change only" stand point, I would think. A 279/289 cam may be shorter on working duration than it first appears, if it is an older lobe type with big lash.
[Re: mikeysmopars]
#2076969
05/20/16 08:19 AM
05/20/16 08:19 AM
gregsdart
I saw a single external pick up and dragster type pan............. That's what it is, Milodon. Have you run this pan at the track? I couldn't keep it from losing oil pressure when hard on the brakes, running ten quarts.
[Re: gregsdart]
#2077016
05/20/16 10:37 AM
05/20/16 10:37 AM
deaks
robin hood country
Once above the torque peak the penalties for low compression diminish a bunch I am sure. At peak torque reversion should be gone, so the power loss could be figured from a "compression change only" stand point, I would think. A 279/289 cam may be shorter on working duration than it first appears, if it is an older lobe type with big lash. Unfortunately the torque figures under the curve aren't on the pics so we can't say for sure, also with max torque at 5600, i'd assume that the converter needs to stall at least that. So what are your opinions on the cam i thought of using in my 470 ? Mick
[Re: deaks]
#2077029
05/20/16 10:59 AM
05/20/16 10:59 AM
Posts: 75,094 A Banana Republic near you.
JohnRR
Once above the torque peak the penalties for low compression diminish a bunch I am sure. At peak torque reversion should be gone, so the power loss could be figured from a "compression change only" stand point, I would think. A 279/289 cam may be shorter on working duration than it first appears, if it is an older lobe type with big lash. Unfortunately the torque figures under the curve aren't on the pics so we can't say for sure, also with max torque at 5600, i'd assume that the converter needs to stall at least that. So what are your opinions on the cam i thought of using in my 470 ? Mick We ran the Hughes HTL7276 ... maybe it was the 6872 ?? ... in the enginemaster entry, if I remember right the torque peak was at 5000 rpm ... over 600lb/ft and HP was still going up when we stopped the pull at 6700 rpm, contest only pulled to 6500 rpm and it was making over 700hp. I think the heads flowed 330cfm, static compression was 12.2.
[Re: deaks]
#2077107
05/20/16 01:55 PM
05/20/16 01:55 PM
Thumperdart
State of confusion
I can't get my head round this, i was told a .625/.625 275/283 on a 107 was too big for my 470 with 440-1 heads with bowl and guide work, same comp, and yet here's a motor with a .776/764 279/289 at 0.50 and it make all this power, surely it should be a mutt down low but it makes over 700 hp at 6000 ? Mick Told by who? I run a .680-.660 Isky solid roller w/276-281 @ .050 w/lowly home ported RPM`s and 12.1.1 compression and it runs/drives just fine on the street..............
[Re: gregsdart]
#2077109
05/20/16 02:02 PM
05/20/16 02:02 PM
Thumperdart
State of confusion
Once above the torque peak the penalties for low compression diminish a bunch I am sure. At peak torque reversion should be gone, so the power loss could be figured from a "compression change only" stand point, I would think. A 279/289 cam may be shorter on working duration than it first appears, if it is an older lobe type with big lash. Greg, Jason only uses CompCams and they grind what HE wants em to............
[Re: Thumperdart]
#2077170
05/20/16 04:00 PM
05/20/16 04:00 PM
Posts: 1,608 fresno ca
mikeysmopars
fresno ca
Here is the cam spec sheet
Founder and CEO of the Central Valley Mopar Drag Pack
[Re: mikeysmopars]
#2077371
05/20/16 10:41 PM
05/20/16 10:41 PM
Posts: 1,454 Glendora Ca.
Just-a-dart
Glendora Ca.
Mike glad to see you have a happy motor, and that things worked out with Pettis.
"Just a Bracket car dressed up like a streetcar"
[Re: Thumperdart]
#2133307
08/15/16 08:19 AM
08/15/16 08:19 AM
deaks
robin hood country
Just updating this thread, wondered when the car is back at the track. Mick
[Re: deaks]
#2133377
08/15/16 11:35 AM
08/15/16 11:35 AM
mikeysmopars
fresno ca
Will be running it in two weeks at Famoso in Bakersfield. It will be hot but I'm hoping for a decent gain, I'll update right afterwards.
[Re: deaks]
#2133426
08/15/16 12:29 PM
08/15/16 12:29 PM
Posts: 11,728 Portage,michigan
B3422W5
Portage,michigan
How does such low comp feed such a big cam ? That was the same thought I had( especially with the "low" compression. At 770 horse and 3150, car should definitely threaten the 8's.
[Re: Thumperdart]
#2133480
08/15/16 01:12 PM
08/15/16 01:12 PM
fast68plymouth
So. Burlington, Vt.
My prediction is 9.40's-.50's @ 140-142.
[Re: fast68plymouth]
#2133509
08/15/16 01:58 PM
08/15/16 01:58 PM
B3422W5
Portage,michigan
My prediction is 9.40's-.50's @ 140-142. The guy who bought my old car upgraded the motor and had it dyno'ed by Best Machine. It made just a tick over 700 horse. It went 140 on S/S springs at 3220 pounds. 9.62 et. Another 70 horse and 70 pounds less weight should run a whole bunch better than that, hence my comment it should threaten the 8's.
[Re: Thumperdart]
#2133868
08/15/16 09:46 PM
08/15/16 09:46 PM
Posts: 19,384 Las Vegas
Al_Alguire
Las Vegas
At that weight and power if EVRYTHING is perfect it might dip into the .30's in really good air. He wont have really good air at Bako in two weeks. I would guess it will run well and make use of that cage and wondow net. And don't think Dwayne is to far off...
[Re: mikeysmopars]
#2135523
08/17/16 11:48 PM
08/17/16 11:48 PM
gregsdart
Here is the cam spec sheet Those cam numbers are virtually spot on (1 degree) to an Isky RR735 I started out with in my motor, including the .200 duration numbers. The only difference is the lash spec, .026/.028 If I recall correctly.
[Re: Al_Alguire]
#2135548
08/18/16 12:29 AM
08/18/16 12:29 AM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
At that weight and power if EVRYTHING is perfect it might dip into the .30's in really good air. He wont have really good air at Bako in two weeks. I would guess it will run well and make use of that cage and wondow net. And don't think Dwayne is to far off... I'm with you two.
[Re: Thumperdart]
#2135740
08/18/16 11:39 AM
08/18/16 11:39 AM
mikeysmopars
fresno ca
One thing I forgot to mention is the car is certified,im not. I'm using this event to get my license so I hope I can complete it as well as get a decent run. If I can't get it done the end of this month I will be back in mid September do Mega Mopar.
