Look in the Jeg's catalog, genius...
Surprised even you can recognize fuel differences today...
You MAY be catching on...
Here's a 600 hp carb setup:
Holley 750 cfm 4150 is $740.
http://www.jegs.com/i/Holley/510/0-80528-1K/10002/-1?parentProductId=Holley red pump is $117.
http://www.jegs.com/i/Holley/510/12-801-1/10002/-1Holley tuning kit is $110.
http://www.jegs.com/i/Holley/510/36-182/10002/-1Total is $967. Then, you spend all day jetting and making passes then jetting again to get it all dialed in. When the weather changes you do it all over again.
Here's a more common setup:
Holley 770 Street Avenger is $538.
http://www.jegs.com/i/Holley/510/0-83770K/10002/-1?parentProductId=1118144Holley mechanical fuel pump is $131.
http://www.jegs.com/i/Holley/510/12-440-11/10002/-1Holley tuning kit is $110.
http://www.jegs.com/i/Holley/510/36-182/10002/-1Total is $779. Then, you spend all day jetting and making passes then jetting again to get it all dialed in (or just drive around in circles instead of making passes). When the weather changes you do it all over again.
FiTech 600 hp EFI system is $995.
http://www.jegs.com/i/FITech+Fuel+Injection/546/30001/10002/-1FiTech Fuel Command is $395.
http://www.jegs.com/i/FITech+Fuel+Injection/546/40003/10002/-1Total is $1390. You spend the afternoon installing it then go drive the car. It tunes itself. No more smelling like fuel and bending over a hot engine while trying to not scratch the fenders.
Another system is due out 4/1/16 that will run a 400 hp engine and save you $200.
Yes, carbs are cheaper but the prices are getting pretty close. The time spent tuning a carb turns into cruising down to the local watering hole.
