Power windows finally installed. Not a simple task on a door that is 3" wide ( ID ) at it's widest and the bottom of the door tapers down to about an inch. Did I mention the door is also curved!! Only system that would remotely work was "Specialty Power Windows" kit. As you can see from the pics, I had to do some home grown mounting work to gain the room I needed. Biggest problem was the taper at the bottom of the door - where the power window motor sits - ugh!
Fastest 300
