Quote: just wondering out loud here. what thickness is the chassis rails ? and with all that plate in the floor, how heavy will it end up being ? with that mass, it should be a good riding car with the correct spring package. incidentally, what rate springs does it use ?
Chassis rails = 1/4" wall 2X4. Weight = guess 21-2300 lbs. Car will be fully equipped as a driver - heat, A/C, full exhaust, undercoated, etc. Spring rates; Carrera QA1 adjustable coil overs on all corners. frt. 200 / rr. 125.
