I would go with a set of t&d if you can. If not see what Hughes has to offer as Andy suggested. I have been using the t&d for the last 8 years spraybar oiling with no issues of yet. Haven't heard anything from you since mopartech died. Good to see you still have you barracuda.
Good to see you around and it has been a while since I've been on the boards. I talked with Scotty a while back and he seems to be doing good. I built a Grand National that I plan to go to the track with. Should make 600 hp at the tire and be good for some easy 10's. I've been neglecting the Cuda for the last 10 years and it's coming back to bite me.
