Okay, so I have another under dash wiring harness, however it is to a non-rallye gauge cluster. I just want to start the engine, so what are the minimum connections I need to make to fire the motor. Obvious ones are red and black to power dash, ignition switch and what else? I am going to pull the old harness and go through it wire by wire before I re-install it. Dave in Colorado
