Quote: 10-4, I seem to recall something about possible wire corrosion by the battery, as that's where the computer is. Though it might be FWD vehicles of that era I am thinking of. Not trying to steer you wrong, but it's been a while.
Try wiggling the wiring around and see if the signal changes, that would indicate an intermittent issue.
I browsed Rockauto to see if they had a computer for you, no California emissions with an auto listed. They have Cal with a stick and Federal for both.
For sure. I was looking at NAPA and they've got one for me for 214 after the core. I was so hoping it was some short I missed when I went through the whole harness while the engine was out. But it's looking like it might be the computer I think. I don't see why it would throw that code when I'm getting good readings from the sensor all the way to the computer. Unless it's an intermittent thing like you said. But I don't think it is because it seems to be constant. Never runs perfect.
