Quote: Honestly, I don't think it is too bad. I had planned to run larger lines anyway. I had been research about how to modify the fuel tank to support EFI and that seems pretty pricey and still requires new lines etc. If your system eliminates the need to change the tank and all else being equal...it would probably be cheaper then a new tank or a Phantom style system. Maybe I am missing something though
If you run larger lines to the front then it would work fine.. that way you can keep the stock tank and the stock sending unit but would still need a small supply pump.... but his tank has enough volume to handle heavy loads for some time period
