The stock replacement steel lines (3/8" supply, 5/16" return) work great on the pressure side of my EFI setup. Mine is a ~550 HP 496 with pump rated for 700 HP. Would probably work fine with higher HP as long as the pump has an un-restricted feed (pump in tank or sump with -10 lines or bigger feeding the high pressure pump inlet).
