Also, found this pic where I ran a sweep pattern without the lash caps.
I tried to locate a comparable photo (I thought?) I took of mine w/ the Hughes rockers, but came up w/ nothing...
What I do remember is that the pattern was definitely narrower, although a bit biased on the intake-side of the valve tip (starts on the intake side and ends up closer to the center at max lift).
Sorry OP for the hijac. It's kinda related as us Victor guys need all the help we can get. We seem to be the underdog
Amen, brother!
