Quote: I decided to run the caps only because the sharp rockers sweep the roller toward the outer tips of the valves and wanted more contact. I'm sure it's not the ideal setup but seems to be working OK.
Another example of HS BBM rockers' being too long between the pivot point and the centerline of the roller. Not a big fan of them, but I seem to be in the minority w/ that opinion.
Mike Beachel
I didn't write the rules of math nor create the laws of physics, I am just bound by them.
