A longer valve would only make this situation worse, as would lash caps. The OP said the rocker had a lot of angle which would be made worse with this approach, not to mention have terrible geometry. The rockers are manufactured with plenty of clearance for the spring if the rocker is properly located. It needs to be moved to the right place!
My question has always been this. How could a company that's made as many heads as Edelbrock, screw up the rocker shaft location on the Victors so bad? All I hear about these heads is how rockers and push rods don't fit.
Doug
