.674 sollid roller,
I'm right in the same ballpark lift-wise.
PAC-1243)installed at 1.900
Same springs & installed height.
Comp tool steel retainers...
I'm using ti retainers, which I'm good with as long as the springs don't have dampers that wear into them.
Smith Bros .375x.083 pushrods
I'll be getting some new SB pushrods, but plan to use .120" walls for this much spring pressure
Harland Sharp S70016EVK rockers.
Hughes' stuff on RAS shafts; no lash caps
Also, don't forget about the possible center rocker stand breakage issue. I preemptively removed the factory helicoil and drilled/tapped and installed a 1.0 inch helicoil further into the head so the top of insert is just below bottom of stand.
Did that to mine after seeing the posts on the broken center stands.
