Cant remember who I called to ask about that filter, but I was told it couldn't handle the output of that black pump. Get a different filter type. Mine is noisy as well, but I got a good deal on it, so for the time being, its on the car.
That's BS. That fram filter is made to go after the pump and can easily handle a black pump discharge volume. All filters are made to go after the pump. Please don't be one of those geeks who have the pump and filter hanging out the back of your car for everyone to see with the filter between the tank and pump showing everyone you don't know how to plumb a fuel system. Like Cab said...and you know now.
Use a AN fitting in the tank with a cone shaped stainless strainer built in and no other restrictions before the pump. Only a strainer with 100 micron screen or courser should be in front of the pump. Even a strainer housing creates turbulence in the fuel flow. And the inlet plumbing to the pump should be larger than the discharge plumbing with very little restrictions(like least amount of 90, 45s and no filters)
The reason pumps are noisy is because they are screaming for help, cavatating there brains out and dieing a slow death. Warmer the weather get's, the more important that the fuel inlet plumbing is right.
Think you`ve got it backwards here................100 BEFORE 40 AFTER at least sez the baddest pump builders/designers around. I used one of the Earls flat screen filters and watched my pressure drop to zero as I pressed the gas then back to 6 1/2 when released........
72 Dart 470 n/a BB stroker street car `THUMPER`...Check me out on FB Dominic Thumper for videos and lots of carb pics......760-900-3895.....
