So it's OK to transfer the drivetrain over to a 318 car and completely rebody an original high dollar pedigree car as long as you screw it's original fender tag back on?
Different topic. No.
"Sheet metal on a 318 car is pretty much the same as a Hemi car".
Sheet metal from China (or any other non orinal Mopar part) is NOT the same as original sheet metal from a 318 or Hemi car and certain original sheetmetal parts are most definitely used to identify a car's pedigree..
No disagreement. Sheet metal replacement discussion is a red herring to discussion on original/replacemement fender tags. If you'd like, you can start another thread on how it affects value and documentation.
Seeking:
1969 St. Louis plant VINs, SPD, and VONs. Over 2,000 thanks to you!
