Use a small OD resin cut off wheel it may take a few to since they have to be small od and cut a slot up and across one side of the nut then rotate 180 degrees and cut another slot up and across to meet the other slot. Them take a cheisel and split the nut off. As mentioned cover up the area around the nut to protect the wheel as much as possible.
