Put a couple lugs back on semi-loose. Lower the wheel to touch the ground and to put pressure on the stud to hold it. Try and put the loose stud at the 6 o'clock position. even though the wheel may be hub centric it should put enough pressure on it to hold it. be careful and use an impact to zip the lug off.
