Re: Pushing breathers out, oil seeping past
[Re: Sport440]
#1649278
07/23/14 12:15 AM
07/23/14 12:15 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Definitely cut and get the breather nipples off the baffles.
Your evac hose is already Off/disconnected at the header and muffler system, so that is not Back pressurizing it.
Forget about hooking up a vaccum test port at the fuel pump block off plate. You dont have any vacuum. You have positive pressure. The leaks may be helped or stopped by sealing the breathers and reducing the nipple length to get them off the baffle plates.
Start there, if you still have to much positive pressure, oil will come out of the filters on the breathers. Then, you have Bigger problems, loss of ring seal or leaking head gasket.
He can measure how much pressure is there if he used the vac port (anywhere in the crank case system) I had a port in the back of the valve cover to monitor my vac.. he can use a compound gauge or a balance tube
Entire Thread
mshred
07/21/14 04:44 PM
Airwoofer
07/21/14 05:16 PM
Thumperdart
07/21/14 05:37 PM
FlyFish
07/21/14 06:12 PM
rt66jim
07/21/14 09:02 PM
mshred
07/21/14 11:22 PM
Crizila
07/21/14 09:07 PM
Crizila
07/21/14 09:41 PM
mshred
07/21/14 11:26 PM
Crizila
07/22/14 01:16 AM
mshred
07/22/14 05:29 AM
MR_P_BODY
07/22/14 05:43 AM
mshred
07/22/14 06:06 AM
MR_P_BODY
07/22/14 06:17 AM
mshred
07/22/14 03:05 PM
Thumperdart
07/22/14 05:37 PM
mshred
07/22/14 11:56 PM
Crizila
07/23/14 02:47 AM
cudadoug
07/23/14 03:05 AM
Sport440
07/23/14 03:47 AM
MR_P_BODY
07/23/14 04:15 AM
pittsburghracer
07/23/14 04:34 AM
MR_P_BODY
07/23/14 04:46 AM
pittsburghracer
07/23/14 05:00 AM
MR_P_BODY
07/23/14 05:12 AM
Monte_Smith
07/23/14 06:04 PM
MR_P_BODY
07/23/14 06:23 PM
STEFF
07/23/14 06:30 PM
Crizila
07/23/14 07:55 PM
Quicktree
07/23/14 07:34 PM
Crizila
07/23/14 08:00 PM
Crizila
07/23/14 06:34 PM
pittsburghracer
07/23/14 06:39 PM
Crizila
07/23/14 08:03 PM
pittsburghracer
07/23/14 08:05 PM
Mopar-Al
07/23/14 04:51 AM
mshred
07/23/14 05:59 AM
Crizila
07/23/14 04:38 PM
Sport440
07/23/14 08:38 PM
mshred
07/23/14 10:41 PM
Bad340fish
07/23/14 11:45 PM
mshred
07/24/14 12:15 AM
Sport440
07/24/14 01:23 AM
dvw
07/24/14 10:28 PM
mshred
07/24/14 10:41 PM
Clanton
07/25/14 12:14 AM
Mopar-Al
07/22/14 06:42 AM
Thumperdart
07/22/14 07:12 AM
MoparBilly
07/22/14 08:25 AM
mshred
07/22/14 03:03 PM
mshred
07/22/14 03:08 PM
mshred
07/22/14 03:06 PM
Crizila
07/22/14 04:13 PM
MR_P_BODY
07/21/14 09:14 PM
mshred
07/21/14 11:27 PM
Dartwizer
07/21/14 09:17 PM
Crizila
07/21/14 09:45 PM
mshred
07/21/14 11:29 PM
MR_P_BODY
07/22/14 12:18 AM
D-50
07/22/14 01:08 AM
mshred
07/22/14 05:21 AM
