How about this pump?
http://www.summitracing.com/parts/pfs-70150/overview/
It could be marginal... as you add pressure you reduce
flow rate... so it might be a issue depending on
how much boost you plan on and rpm
How about this one
http://www.summitracing.com/parts/vpn-gsl392bx/overview/
To be honest you dont need that pressure but you want
flow... will it work.. yes but thats a lot of wasted
pressure so you need a good return(big)
