Quote: Can anybody plot the range and trajectory of a carburetor after it goes thru the hood under a 10 PSI of boost backfire? 20 PSI?
What would the effect be steel vs 'glass hood, right vs left carb?
Seriously, quickd100 has had some success blowing up a 318 with a draw thru running a single Thermoquad and making the numbers you are looking for and then some.
