I bought some Permatex High Tack adhesive. I am hoping this with some lock-tight on the pan bolts threads will work. I am hoping this will help me stick the gaskets together and keep them weep free. Part of the problem is with the time it takes to get the tray and pan together, most sealants are already partially set.
Read my post on what was suggested, that has and does, flat work on a lot of motors(150+), gasket adhesives are intended to attach gaskets to parts, not make them oil weep free ![](/ubbthreads/images/graemlins/shruggy.gif)
