Nice work on this.
I will have to trim the upper stud after install, but no big deal.
I was going to keep an eye on the upper stud on mine. See if it shows any sign of making contact.
Also, my lower stud is 4" off the ground.
The only problem with trimming it is you lose the 8mm cut end which keeps the post still while you tighten the provided nylon nut.
Yeah that is tricky. I bet when you get it on the ground it might be close. I would cut if need be, grind a small area of threads off so you can grab it with a vise grip. After you grind, you can always run a tap over the old threads to clean it up.
The Moog version did not have the end cuts so....maybe it locks itself in place when it starts to snug up to the bar. We will see.
