I believe that when the bypass opens,you are bypassing the filter and NOT filtering the engine oil
It does it right in the pump so no it doesnt see the filter... its no big deal since it has to go to the filter before it goes into the engine(bearings and so)
So are you saying all the oil is being filtered by the Wix oil filter?
1970 Duster Edelbrock headed 408 5.984@112.52 422 Indy headed small block 5.982@112.56 mph 9.42@138.27
