There is nothing wrong with the oil pressure Cut the oil to 6qts total and see what happens. The worst thing you can do is foam the oil with too much in pan. I raced a 340 engine with 40-45 psi total pressure period hot or cold and never had a issue, for years. Just stay away from HV pumps. I prefer to modify the stock pumps
