Are you using the same oil pressure gauge on both motors? If not maybe your seeing a difference between gauges I know a lot of the Mopar SB drag race guru in SO CA do NOT recommend using the high volume or high pressue oil pumps in those motors as already sia on whipping the oil by being over full I always calibrate the oil dip stick to the pan, not vise a versa
