Hi Dr.diff and all.
A-body 8-3/4 axle, (shafts from you).
Had a Yukon shaft failure with an old style sure-grip!
The clutches slipped on one side and tore the end off the shaft???
I see the engagement into the inner drive gear is only around 3/16's of an inch.
Is this a common fault with the split gear early locker???
I see the new style track-lok I got form you has a one piece side gear.
Will it be ok to re-use the shaft with the new track-lok?
Also heard different opnions on the inner axle seal?
Leave it in or take it out, to stop overheating of the greens???
Thanks from England, Gtxjon.
