Re: Green Bearings
[Re: Fury Fan]
#134462
10/17/08 01:07 PM
10/17/08 01:07 PM
Posts: 1,568 Omaha, Nebraska
Scott Carl
Omaha, Nebraska
This topic is a good example of one of my favorite phrases: 'Just because someone knows how to work on things doesn't mean they know how things work.' There are good points (and bad points) brought up by both sides here.
About a year ago I found a copy of this article, today I was able to find it on the web. I encourage everyone with an interest in this topic to read this article and learn a little about bearings. It clearly explains the advantage the tapered bearing has over a roller bearing in a wheel bearing application.
The factory application/designs have a Factor Of Safety associated with them, and it's evidently high enough that a lower-capacity roller bearing can be installed in its place without a tremendous amount of failures.
The roller bearing is clearly inferior to the tapered roller from a load-bearing perspective, however there are other factors in a rear axle application that are the reason this topic brings passionate feelings from both sides. We should focus on simple things like engine oil or filters instead.
As for me, I'll stick with my Timken rollers, clean/re-grease them periodically, and worry about my other worries instead...
http://www.schaeffler.com/remotemedien/m...here_roller.pdf
Awesome article! Very informative. Thanks, FF Scott
