At the risk of beating a dead horse on this issue, a question has come to mind. As I understand the Grenn bearings, their main advantage, besides the need for adjustment is eliminated, is that they are sealed. Correct? Is it simply not possible to do with a tapered bearing? Not suggesting that they are better or ball is worse, Just asking the question. Is there a sealed tapered bearing on the market?
