It totally helps. Are you having to space out your front wheels? I saw this is an issue on the fronts with a dakota and viper brembos. I have also read that the caliper position is not all the way on the rotor on the front?
Is this true?
Or is that the bracket that is used on the late model spindle?
I don't know yet I actually only have the brackets right now calipers and rotors are on the way. Then I need to turn the hubs down so the rotor fits all the way on. Once I get it installed I'll know more
That was another thing...the kit, or one of them anyway came with hubs I remember. Not because the same one doesnt work on the differnt spindle, but for that reason....rotor fit. I'd like to leave my hubs unchanged so if I kill a bearing *which is known to happen with these things) I can hippety hop on down to the parts store and be back in business without a trip to the machine shop. but maybe I have no choice...
