The 14.2" rotors are only like $170 ? or so right from Mercedes by the way..
Not as cheap as the setup you have..but still a heck of a deal for what they are I think.
I've got a pair of brand new PBR twin piston calipers here too actually..they (along with some off the shelf adapters from Oz I have) bolt right onto the Aussie Mopar spindles When I have nothing to do, just have to find a rotor to fit it..they use a 2 piece rotor/hub setup so having just the hubs to mount larger rotors on is only knocking-out-the-wheel-studs away.
