I'm not dead set on keeping the 3.23's. So I'll probably just find another third member so I don't have to use my #'s one. I know my old man has more than one sitting around the house and one is a 3.91 gearing. I'll probably go with the .474 to work with my AC and with a 4 speed it should do pretty good in the 1/4.
I sent comp cams a request to get there 2 cents. I'll probably just stick with MP.
If you do stick with MP, the grind you would go with would be P4452993, 280/474 110CL. Good cam, with 3.91's will work well at the strip/street. The 3.91's CAN be changed when not running at the strip, RUN taller tires to raise effective gear ratio on those highway jaunts. Try to use a small single plane, or step to the Eddy Performer for good power. If you have good flowing heads run the Performer RPM. I know that the 4-throw is pretty self explanatory, run a carb (650-670 cfm for good snap thru the gears) with vac secondaries for econo/power. If not going with the MP cam, you might want to try Hughes Engines. Their hydraulic cams work very well and make torque/power. They are on the Internet. Food for thought!! Good luck with your 383!! It will run well!!
"Stupidity is Ignorance on Steroids" "Yeah, it's hopped to over 160" (quote by Kowalski in the movie Vanishing Point 1970 - Cupid Productions)
