Looking at your spec card, it looks like comp decided to use almost all the same specs but shorten the intake duration and lengthen the exhaust duration. Not a bad idea utilizing the larger exhaust valves on stock heads, or any other head for that matter.
Project War Bird:
1971 Plymouth Roadrunner
383 4 speed with air conditioning
GY3 Curious yellow
All original
