Bill
Was the name plate only on the drivers side? The reason I ask, is because the 70-71 parts book only lists 1 required.
I think it was a slip in the parts book... same two pin nameplate used on both left and right side, 3443246 cast on the backside...3 pin shaker is 3577361 cast on backside, same one for both sides of the shaker scoop
