for me my biggest concern would be $$$. if you have a good stock crank then stay with the stock displacement. if you need a crank then you might find a mild stroker rotating assembly the same or extremely close priced to stock parts. these parts might even be better quality than 50+ year old stock parts. if you add displacement the chevy rod journal sized stuff is bolt in also.
