I wonder why you are having clearance issues? I run a lot more lift and don't have any clearance issues. 268@.050 exhaust is 27x @.050. .465 lobe with 1.6 rockers. With the victor heads you will want to run as much lift as possible.Have you considered cutting the valve reliefs deeper? https://www.lindytools.com/ihpc
