Vizard has stated pretty specifically that flow during OL is far more important than suspected previously.
When heads are flowed, is that with a 12.0:1 CR domed piston below the (partially open) valves? At full lift, there is almost no intake vacuum, while (assuming a good exhaust) at OL vacuum from the return pulse may be 7".
Flow bench: useful Dyno: more useful LSR: most useful
