Quote: Stock uncut body and interior (25K miles) KG2 Frosty Green Metallic w/V1W white vinyl top F3G6 green cloth and vinyl split bench seat w/center armrest Weight 3450# Carpeting Stockinteriors.com Jade Green cut pile (new) Air conditioning 134 Cruise control OEM Radio AM OEM Remote trunk release - OEM Tachometer Autogage Auto Meter 8K w/external shift light (new) Wheels 14X6 ralley Tires B F Goodrich P225-60R14 Hood Fiberglass Unlimited flat (new) Steering Power Brakes Power front disc/rear drum Line Lock Enterprise (activated by horn ring) Transmission 727 automatic w/Red Eagle Friction and Kolene steels (new) Transmission pan Mancini steel deep sump w/extension (new) Valve body TCI Streetfighter (new) Converter Hughes 24-25 2600 stall (new) Flex plate 440 Source SFI (new) Shifter Hurst Pro-Matic 2 Shifter handle PowerSHIFTER.com (new) Differential 8.75/3.23 SG Axles Moser LBP (new) Rear suspension Mancini HD leaf (new) Front suspension MP 1.080 torsion Engine 1968 RB 440 block .30 over Crankshaft OEM steel .10/.10 under Pistons Speed Pro L2355F30 forged (new) Rods 440 Source 5140 forged (new) Balanced rotating assembly Windage tray MP (new/modified with more drain louvers) Oil pump Melling std (new) Oil pan - OEM Water pump and housing 440 Source aluminum (new) Lifters 440 Source HD anti pump-up (new) Timing chain 440 Source double roller billet 3 bolt/3 way (new) Heads Edelbrock RPM aluminum/exh ported/matched (new) Head bolts ARP (new) Camshaft Lunati Voodoo hyd 268/276-.527/.547@1.6 (new) Valvetrain MP 1.6 roller rockers/Mancini chrome shaft (new) Pushrods MP HD 3/8 in. (new) Distributor - OEM Ignition OEM/MSD 6AL w/5500 chip (located inside front battery) Coil MSD Blaster Intake Edelbrock CH-28 dual quad/dual plane Carburator Edelbrock 1405 2X600 cfm Safety switch Summit oil low pressure cutoff Headers Schumacher Tri-Y Starter MP mini (new) S6-RB conversion - Schumacher (new) Frame connectors Mancini bolt-in (new) Exhaust Summit full 2-1/2 in. (new) X-pipe Summit (new) Radiator Summit 26 in. aluminum (new) Plug wires Taylor 8mm (new) Fuel pump OEM (new) Fuel tank sending unit Matts Classics 3/8 in. (new/modified to add 5/16 pickup) Nitrous NOS Super Shot x2 Holley Blue electric (activated by OEM rear defogger switch) Holley fuel pressure regulator Holley analog fuel pressure gauge
So....what's it run...that is if it's not top secret. If so I totally understand! That thing is awesome!
Hi JD. I don't know what it runs, sorry. It's not real good in the traction department, just fun. The grandkids call it the grandpa car. It's fun taking it to the local car shows cause it is relatively stock looking even under the hood and yet can be a hand-full when playing.
