I should take some new pictures, i've made a bunch of changes since these were taken. The carbs are modified 850 thermoquads fed by 2, 140 gph pumps though a very large filter and 1/2" fuel line. I've freshened the tranny and installed a 8" TA converter, and installed a set of rancho 9000 adjustable shocks to compliment the homemade caltracks. The big question now is, will it hook on a set of 30/10.5 slicks? I've also painted the fuel lines, valves, and pumps flat black to try and blend them in to the background. Dave
