The Manual that Tim Hyatt produced for me was turned all the way out CCW was 200 lbs with a certain number of shims between the PP and flywheel attachment bolts. I will need to look that up for you.
Turned all the way in CW is 1200 lbs of base on the McLeod Softloc...
My Ram Long Style with weighted fingers is 1800 base, and adjustable to 800 lbs. Ram sells a number of Long Style 11” under truck pulling PP’s.
Ram and McLeod are exactly the same, just a different color, and the Ram is 11” and McLeod is 10.5” PP.
McLeod sells both the 10.5” and 11” sintered Iron Discs for a great price. Ram and McLeod used the Same supplier for the disc’s. I can’t tell the difference.
Seems Ram is more interested in working with the end user, and McLeod wants you to work with a racing clutch shop.
BR, Mark
