Re: Graveyard carz, Prepaint technique. Paint explain, opinions
[Re: 65pacecar]
#2280632
04/01/17 11:47 PM
04/01/17 11:47 PM
Posts: 18,157 Mass
DAYCLONA
Mass
Seems like a lot of painters like to paint cars "thier way" (which of course is always the best way) LOL! Whats wrong with using the factory procedure? Seems that everyone wants to fight the tried and true factory method of painting with all of the panels gapped and adjusted before paint, etc. I agree but it addresses the question I asked earlier. How does ONE person make it everywhere on the car without getting dry edges? Example: Starting with the hood, doors and trunklid open, you spray the "hidden" areas then close up and spray the outer body. How do you get paint everywhere and still not come back to areas that have already dried? Great explanation. Do you always go BC/CC or domyou still spray SS at Times? I think some confusion has taken place in this thread, the initial question of the OP is the painting of the "jambed" areas with a SINGLE STAGE paint, then finishing the outer body in a 2 STAGE FINISH, which often results in a slight color and or sheen/gloss texture change either right after painting or as the finishes age, GYC has termed this "El Cheapo" technique as "Pre Painting" as if it's something new,...it's been done for decades by cheap painters/owner who don't want to "waste" 2 stage, or the time of applying clear coat in the "jambed" areas... Frankenberry I'll take you thru my procedure, 1st whatever paint is being applied to the body is used THRU OUT the entire structure, EVERYWHERE...after the vehicle has been bodyworked and primed and blocked to death, I'll remove the hood, doors, trunk lid and any other panels that have hidden areas, all the jambs, backsides,the interior,engine compartment, flanges, tabs, etc, etc are painted, then the panels are hung back on the car and realigned, then backtaping and aperture tape is applied in all jambed area to create a soft spray edge as well as a blending line for the outer body paint and the previously jambed areas so that after the body is sprayed the transition of the outer body painting blends into the jambed areas with little to no noticeable sheen difference, which can be polished with no effort later when the outer paint is cut and buffed, if a jambed area can be painted while doing the entire outer body then do it at the final painting session,but basically when I'm in the final painting stage, all the panels/doors/hood/trunk/etc are in place in the closed position with backtaping and aperture tape in place, when I'm done with a vehicle, it has the same gloss/texture and color thru the vehicle, there's a lot of masking, backtaping, aperture tape, papered areas etc, but when it's done it looks like it was painted all at the same time with no exposed/unpainted areas unless they were intended as such, as in an OEM underside application/finish Mike Great explanation. Do you always go BC/CC or do you still spray SS at Times? While I like the look of a wet slick paint job that BC/CC can achieve, I'll spray any paint, single stage, 2 stage (BC/CC) or 3 stage...be it Imron, Acrylic Enamel, lacquer, urethane, etc, whatever the project requires, or the customer desires... I sprayed single stage and lacquer with the same technique described above back in the 70's and 80's, whhe BC/CC came on the market in the mid/late 80's I still employed the same technique, it involves a lot of planning, taping, aperture tap, paper and labour, and money which a lot of shops or individuals don't want to invest in, I've worked aside with other painters or bosses, even owners in the past and present who start freaking out about how much paint I waste, or tape, paper, etc, etc, but I always say after the paint work is done, that the expense and time were worth it Mike
Entire Thread
modelmakerinc
03/31/17 12:50 PM
Mr T2U
03/31/17 01:34 PM
killermopar
03/31/17 01:55 PM
Stanton
03/31/17 03:31 PM
DaveRS23
03/31/17 03:36 PM
mgoblue9798
04/01/17 06:10 PM
Supercuda
03/31/17 04:10 PM
RUNCHARGER
03/31/17 05:17 PM
DAYCLONA
03/31/17 07:26 PM
flypaper
03/31/17 07:36 PM
ek3
03/31/17 09:01 PM
Stanton
03/31/17 09:22 PM
DAYCLONA
03/31/17 09:27 PM
FuryBoy
03/31/17 09:35 PM
Kern Dog
03/31/17 11:58 PM
stinger
04/01/17 01:22 AM
Stanton
04/01/17 02:07 AM
Spaceman Spiff
04/02/17 07:11 PM
a12rag
04/01/17 04:38 AM
R/T1968R/T
04/01/17 04:45 AM
Stanton
04/01/17 05:46 AM
Sunroofcuda
04/01/17 06:18 AM
moparx
04/01/17 04:11 PM
a12rag
04/01/17 06:30 PM
Spaceman Spiff
04/02/17 07:12 PM
cmansell
04/02/17 11:18 PM
Stanton
04/01/17 04:11 PM
Stanton
04/01/17 04:16 PM
Stanton
04/01/17 09:40 PM
Neil
04/01/17 10:01 PM
Silver70
04/01/17 11:20 PM
Mr T2U
04/02/17 01:18 AM
Kern Dog
04/01/17 10:28 PM
ScottSmith_Harms
04/01/17 11:30 PM
Kern Dog
04/02/17 12:21 AM
DAYCLONA
04/02/17 01:32 AM
65pacecar
04/02/17 02:11 AM
DAYCLONA
04/02/17 03:47 AM
stinger
04/02/17 04:49 PM
DAYCLONA
04/02/17 05:37 PM
Mr T2U
04/02/17 01:29 AM
SNK-EYZ
04/03/17 07:59 PM
Stanton
04/01/17 11:46 PM
Silver70
04/02/17 05:22 PM
crlush
04/03/17 02:51 PM
DAYCLONA
04/03/17 06:25 PM
Charger727
04/03/17 07:02 PM
stinger
04/03/17 07:28 PM
modelmakerinc
04/03/17 11:13 PM
