I am reading this diligently as I have 70 bronco with all wheel drums and now have a pull to the left. No leak showing and flex lines replaced.
I had a similar issue you did on my 67 Vette. Manual 4 wheel disc. I replaced all flex lines with braided lines and the pedal got much firmer than when all stock rubber lines were good..
