If you are still having trouble, post a photo of the problem side. Also if the RR is getting fluid pressure and not the LR, both rears are fed from the T on the axle housing at the same time, any blockage would be from the t to the wheel cylinder. If nothing visual, loosen the problem side from the T and try to get pressure there, work your way to the wheel cylinder.
