Re: not sure, maybe a blown headgasket
[Re: ashburnmike]
#177223
12/30/08 10:30 AM
12/30/08 10:30 AM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
If it is flooding out the float could be set too high or there could be something holding the needle partially open to allow too much fuel into the bowl. When you look down the throat you should not see any fuel dripping. does it smell rich. If it is dripping fuel it should smell rich and the plugs should be black, which you say they are not so possibly scratch that idea. On the other hand like Robert said you have the possibility of a vacume leak. OR have you adjusted the idle mixture screws or just adjusted the idle speed. Poor idle mixture can also give the symptoms you describe. A lot like slowly running out of fuel. We are all just guessing here without being able to see the problem.
Entire Thread
ashburnmike
12/28/08 10:04 PM
RapidRobert
12/28/08 10:32 PM
MoparforLife
12/28/08 11:05 PM
ashburnmike
12/28/08 11:50 PM
MoparforLife
12/29/08 12:25 AM
ashburnmike
12/29/08 12:49 AM
RapidRobert
12/29/08 12:58 AM
MoparforLife
12/29/08 01:09 AM
ashburnmike
12/29/08 01:28 AM
MoparforLife
12/29/08 01:44 AM
ashburnmike
12/29/08 02:00 AM
MoparforLife
12/29/08 02:22 AM
ashburnmike
12/29/08 03:01 AM
MoparforLife
12/29/08 03:06 AM
VITC_GTX
12/29/08 03:30 AM
RapidRobert
12/29/08 03:02 AM
ashburnmike
12/29/08 03:14 AM
RapidRobert
12/29/08 03:40 AM
ashburnmike
12/29/08 03:53 AM
RapidRobert
12/29/08 04:04 AM
ashburnmike
12/29/08 04:24 AM
RapidRobert
12/29/08 04:38 AM
ashburnmike
12/29/08 11:38 PM
FuryUs
12/29/08 11:47 PM
MoparforLife
12/30/08 12:08 AM
ashburnmike
12/30/08 12:09 AM
MoparforLife
12/30/08 12:35 AM
RapidRobert
12/30/08 12:52 AM
ashburnmike
12/30/08 01:10 AM
ashburnmike
12/30/08 01:14 AM
FuryUs
12/30/08 02:01 AM
cupcake
12/30/08 02:34 AM
ashburnmike
12/30/08 02:40 AM
RapidRobert
12/30/08 02:45 AM
RapidRobert
12/30/08 02:36 AM
RapidRobert
12/30/08 01:34 AM
ashburnmike
12/30/08 02:51 AM
DAYCLONA
12/28/08 11:06 PM
buildanother
12/30/08 02:39 AM
ashburnmike
12/30/08 02:47 AM
RapidRobert
12/30/08 02:59 AM
ashburnmike
12/30/08 03:06 AM
RapidRobert
12/30/08 03:30 AM
ashburnmike
12/30/08 12:54 PM
MoparforLife
12/30/08 01:03 PM
ashburnmike
12/30/08 01:45 PM
MoparforLife
12/30/08 02:02 PM
ashburnmike
12/30/08 02:17 PM
MoparforLife
12/30/08 02:30 PM
ashburnmike
12/31/08 02:37 AM
ashburnmike
01/03/09 11:50 PM
MoparforLife
01/04/09 12:16 AM
ashburnmike
01/04/09 01:21 AM
MoparforLife
01/04/09 01:24 AM
ashburnmike
01/04/09 02:06 PM
MoparforLife
01/04/09 02:10 PM
ashburnmike
01/04/09 08:51 PM
69superbee383
01/04/09 09:04 PM
69superbee383
01/04/09 09:07 PM
RapidRobert
01/04/09 09:13 PM
MoparforLife
01/04/09 11:15 PM
ashburnmike
01/04/09 11:51 PM
69superbee383
01/05/09 01:55 AM
ashburnmike
01/05/09 02:52 AM
70dart360
01/04/09 12:17 AM
ashburnmike
01/04/09 01:23 AM
ashburnmike
01/04/09 01:25 AM
RapidRobert
01/04/09 04:42 AM
ashburnmike
01/04/09 02:19 PM
MoparforLife
01/04/09 02:58 PM
ashburnmike
01/04/09 03:25 PM
69superbee383
01/04/09 05:52 PM
ashburnmike
01/04/09 06:16 PM
69superbee383
01/04/09 07:10 PM
BigBird
01/04/09 07:39 PM
RapidRobert
12/30/08 01:18 PM
