Re: not sure, maybe a blown headgasket
[Re: buildanother]
#177212
12/29/08 10:47 PM
12/29/08 10:47 PM
Posts: 455 Ashburn, Virginia
ashburnmike
Ashburn, Virginia
If you have the ralley dash, your fuel gauge could be the cause of your gauges reading too high, as the voltage limiter is part of the fuel gauge, and could cause the gauges to read too high or to low if it malfunctions. Happened to my 340 duster, all three gauges, (temp, oil press and fuel level started reading half of what they should have because of the fuel gauge. I imagine a non ralley cluster may do the same if plug-in style voltage limiter freaks out. Head gasket re-torqing is seldom done, so if the bolts were torqued to correct specs, it should not cause a problem.
Yes it is the Rallye dash. The gauges were steady and stable until this recent occurance. How can you test the gauges? Could that also cause the motor to stumble if the current was interrupted...creating the "miss'
Entire Thread
ashburnmike
12/28/08 10:04 PM
RapidRobert
12/28/08 10:32 PM
MoparforLife
12/28/08 11:05 PM
ashburnmike
12/28/08 11:50 PM
MoparforLife
12/29/08 12:25 AM
ashburnmike
12/29/08 12:49 AM
RapidRobert
12/29/08 12:58 AM
MoparforLife
12/29/08 01:09 AM
ashburnmike
12/29/08 01:28 AM
MoparforLife
12/29/08 01:44 AM
ashburnmike
12/29/08 02:00 AM
MoparforLife
12/29/08 02:22 AM
ashburnmike
12/29/08 03:01 AM
MoparforLife
12/29/08 03:06 AM
VITC_GTX
12/29/08 03:30 AM
RapidRobert
12/29/08 03:02 AM
ashburnmike
12/29/08 03:14 AM
RapidRobert
12/29/08 03:40 AM
ashburnmike
12/29/08 03:53 AM
RapidRobert
12/29/08 04:04 AM
ashburnmike
12/29/08 04:24 AM
RapidRobert
12/29/08 04:38 AM
ashburnmike
12/29/08 11:38 PM
FuryUs
12/29/08 11:47 PM
MoparforLife
12/30/08 12:08 AM
ashburnmike
12/30/08 12:09 AM
MoparforLife
12/30/08 12:35 AM
RapidRobert
12/30/08 12:52 AM
ashburnmike
12/30/08 01:10 AM
ashburnmike
12/30/08 01:14 AM
FuryUs
12/30/08 02:01 AM
cupcake
12/30/08 02:34 AM
ashburnmike
12/30/08 02:40 AM
RapidRobert
12/30/08 02:45 AM
RapidRobert
12/30/08 02:36 AM
RapidRobert
12/30/08 01:34 AM
ashburnmike
12/30/08 02:51 AM
DAYCLONA
12/28/08 11:06 PM
buildanother
12/30/08 02:39 AM
ashburnmike
12/30/08 02:47 AM
RapidRobert
12/30/08 02:59 AM
ashburnmike
12/30/08 03:06 AM
RapidRobert
12/30/08 03:30 AM
ashburnmike
12/30/08 12:54 PM
MoparforLife
12/30/08 01:03 PM
ashburnmike
12/30/08 01:45 PM
MoparforLife
12/30/08 02:02 PM
ashburnmike
12/30/08 02:17 PM
MoparforLife
12/30/08 02:30 PM
ashburnmike
12/31/08 02:37 AM
ashburnmike
01/03/09 11:50 PM
MoparforLife
01/04/09 12:16 AM
ashburnmike
01/04/09 01:21 AM
MoparforLife
01/04/09 01:24 AM
ashburnmike
01/04/09 02:06 PM
MoparforLife
01/04/09 02:10 PM
ashburnmike
01/04/09 08:51 PM
69superbee383
01/04/09 09:04 PM
69superbee383
01/04/09 09:07 PM
RapidRobert
01/04/09 09:13 PM
MoparforLife
01/04/09 11:15 PM
ashburnmike
01/04/09 11:51 PM
69superbee383
01/05/09 01:55 AM
ashburnmike
01/05/09 02:52 AM
70dart360
01/04/09 12:17 AM
ashburnmike
01/04/09 01:23 AM
ashburnmike
01/04/09 01:25 AM
RapidRobert
01/04/09 04:42 AM
ashburnmike
01/04/09 02:19 PM
MoparforLife
01/04/09 02:58 PM
ashburnmike
01/04/09 03:25 PM
69superbee383
01/04/09 05:52 PM
ashburnmike
01/04/09 06:16 PM
69superbee383
01/04/09 07:10 PM
BigBird
01/04/09 07:39 PM
RapidRobert
12/30/08 01:18 PM
