check/clean the plugs/appropriate # of pumps/correct choke setting/fire that puppy up
I will, but i still want more spark for easier starting. Obviously it could use more because normally if it wont start after sitting, it will if i jumper the coil to the battery. and after doing this test tonight, i see why, that spark just looked very week compared to a GM electronic ignition.. Is there a more powerful coil i could use with the existing stuff i got now that will help or..?
Here is a video of a guy using that little spark checker tool i was telling you about. Mine does not have enough ass to spark one! Even when it is running, it doesnt have enough ass to spark one..
