I got to thinking, It wont matter what ignition i use, weather its petronix or electronic, it will still do this because the power going to the coil is triggered by the ignition switch, and if its causing the issue or any of the wiring from it to the coil, its still going to do this, correct? Still, jumpering the coil from the battery should eliminate this like it usually does, correct?
