It does sound consistant with excessive timing but 35 is a tried & true SB norm plus you disconnected the vac adv for an even more conservative total & no change. I wonder if a valve is leaking badly (not sure tho & it sure sounds like ign). there's some connection as to why the dome light (system voltage) dims when it pops. Stay on it
