When I saw the 1 spark, I was not loading the engine. I was by myself and the car was in park. I'll get my gf to give me a hand and we'll give that a try.
with you loading it if you hear a yelp come from under the hood then likely she has found (& can identify) the plug wire that is leaking voltage. Might be 2 problems, the starter and the plug wire/boot EDIT Do you have another coil laying around that you could sub in for a quick test? another dist also (phasing if it's phasing is different from the current one/pickup continuity issue)
