Thanks Ron,
I am going out to the garage soon,,,and pulling the old MC out of the car.
The "new" one supplied with the SSBC system looks to be 1" bore ? ( when i measured it )
I am going to get the NAPA unit,,and be done with it.
I was looking at my brake lines,,,and where i might put the proportioning valve (PV)....not sure if i want to mount it down on the frame,,,,or re-do my brake lines,(which look rough),,and then run the PV up on the fender apron...
I might pull all the brake lines out,,,put new ones in,,,to look nicer,,,and plumb it the right way....
I hate bending brake lines,,,
I have to see if there is a tool to make the job easier and look more professional........
thanks,
Doug
