I always use the transgo kits and have never had one that would frere wheel. I set up the one in my 904 in my cuda with a TF1 with all the biggest shift valve holes and if you manually hit 1st at a high enough speed the rpms go way high your forehead hits the steering wheel and the back end starts sliding around, my engine makes a lot of vaccume
